Ben's blog
moon indicating dark mode
sun indicating light mode
Useful JS libs in my web developments
January 02, 2020
Here a few useful Javascript libraries I’m using in my web projects. Some are famous, some should be. None are framework oriented, you can use it with React, Angular, Vue, JQuery etc.
lodash
Always useful, lodash is a set of utilities to handle strings, iterables, collections, functions. Don’t reinvent the wheel, you will find what you need in lodash. 2 things to keep in mind when you use it in a webapp.
  1. Don’t forget to import only the module you need. You don’t want to import all lodash utilities in your final bundle.
  2. lodash/fp module will you give the ability to use it in a functional programming style.
// import only the debounce function from lodash/fp
import debounce from 'lodash/fp/debounce'
const debounced = debounce(250)(search) // debounce the search function
date-fns
Like lodash, date-fns has a bunch of functions but dedicated to handle dates. This is a great alternative to moment.js It uses the native Javascript Date object and you can import only the modules you need. Formatting, parsing, operations… most of date use cases can be done with date-fns.
import formatRelative from 'date-fns/formatRelative'
import subDays from 'date-fns/subDays'
formatRelative(subDays(new Date(), 3), new Date())
//=> "last Friday at 7:26 p.m."
Day.js is also a good alternative to moment.js. It is a minimalist lib (only 2KB) with almost the same complete API.
validator.js
In web development, you always need to validate user’s inputs. validator.js contains all the validation functions you need: email, alpha, currency, credit cards, MAC address, etc. More than 60 validators!
import isEmail from 'validator/lib/isEmail'
isEmail('foo@bar.com') // true
intl-messageformat
intl-messageformat provides a way to manage and format your app’s string messages into localized strings. It uses the ICU Message syntax and works for all CLDR languages which have pluralization rules defined.
import IntlMessageFormat from 'intl-messageformat';
const photos = `You have {numPhotos, plural,
=0 {no photos.}
=1 {one photo.}
other {# photos.}
const messages = new IntlMessageFormat(photos, 'en-US');
console.log(msg.format({numPhotos: 0})); // => "You have no photos."
console.log(msg.format({numPhotos: 1})); // => "You have one photo."
console.log(msg.format({numPhotos: 1000})); // => "You have 1,000 photos."
DOMPurify
In some webapp, I needed to sanitize HTML string coming from the user or external sources. Most of libs I found were very heavy. DOMPurify is one of the lowest and fastest sanitizer. Very easy to use, you can also override its default configuration.
DOMPurify.sanitize('<img src=x onerror=alert(1)//>'); // becomes <img src="x">
DOMPurify.sanitize('<svg><g/onload=alert(2)//<p>'); // becomes <svg><g></g></svg>
DOMPurify.sanitize('<p>abc<iframe/\/src=jAva&Tab;script:alert(3)>def'); // becomes <p>abcdef</p>
DOMPurify.sanitize('<math><mi//xlink:href="data:x,<script>alert(4)</script>">'); // becomes <math><mi></mi></math>
DOMPurify.sanitize('<TABLE><tr><td>HELLO</tr></TABL>'); // becomes <table><tbody><tr><td>HELLO</td></tr></tbody></table>
Feather icons
Feather icons is just an awesome set of beautiful open source icons.
Alt Text
Faker.js
You are tired to use lorem ipsum text or foo, bar, baz in your unit tests and mockups. So. You have to check faker.js. It can generate addresses, company names, account numbers, phone numbers, images and so on. It supports multiple languages and locales. Here a complete demo
import faker from 'faker'
faker.name.findName() // Rowan Nikolaus
faker.internet.email() // Kassandra.Haley@erich.biz
faker.helpers.createCard() // random contact card containing many properties
And you. Which lib do you use in your web projects?
